There’s nothing quite like the charm of a period home.
If you property is listed though, you may face some difficulty updating it.
Here’s what you need to know before thinking of renovating.
1. Know your grades
The older a building is, the more chance there is that it's listed. As a general rule, listing applies to all buildings built before 1700 and to most built between 1700 and 1840.
The vast majority of listed buildings are Grade II listed, but more important ones are Grade II* and the most important are Grade I.
In Scotland, categories A, B and C are used instead of grades. The listing applies to the whole exterior and interior of the building, and sometimes attached structures and buildings as well.
[Read more: 5 things you should know about wind turbines before getting one]
2. Find out what permission you need
Listed buildings are considered to be of special historical or architectural interest of national importance.
Listing doesn't mean that the building can't be altered or extended - it often can, but the local council will have more control over what changes are made to it and may refuse permission for alterations if it doesn't think they're appropriate.
Listed building consent is required to make alterations and while some home improvements, such as internal redecoration, can often be done without consent, many others, such as removing original features, knocking down walls and changing the windows and doors, can't.
Many local councils identify locally listed buildings, which are considered to be historically important to the area but are not officially listed. You don't require listed building consent to alter locally listed properties, but if you make an application for planning permission, the local listing is likely to be taken into account by the council.
Listed building consent is obtained from your local council and is a similar process to applying for planning permission - sometimes you'll need planning as well. Historic England (see historicengland.org.uk/listing/ for information on listed buildings) or Historic Scotland (www.historic-scotland.gov.uk) may be consulted by the council about whether the alterations would be appropriate, especially with more important listed buildings.
Before making any changes to a listed building, consult your local council's conservation department, as work that seems minor may require consent. The department should be able to offer advice about what sort of work is considered appropriate for the building - and what isn't - and the consent process. Altering, demolishing or extending a listed building without consent is a criminal offence and can result in a prison sentence and large fine, as well as other costs.
[Read more: 5 hidden dangers of the post-war home that could still be lurking in your house today]
3. Get the right materials
If listed building consent is granted, you'll probably have to use traditional building materials and techniques to comply with it.
These are often more expensive and specialised than standard ones - traditional lime plaster instead of conventional modern plaster, for example - as replacements are often on a like-for-like basis.
What are your tips for a period renovation? Let us know in the Comments section below.
