It can be frustrating when you’ve got your home looking beautiful on the inside but the exteriors leave a lot to be desired.
[Read more: Old Hollywood stars' homes to take interior design ideas from]
If your property is ugly on the outside, it can be easier to fix than you might first think.
Here are five tips to get you started.
1. Painting
If your home has a painted exterior, it won't stay looking good forever because the weather will take its toll.
The easiest way to give the exterior a new look is to paint it a different colour, using a high-quality masonry paint.
Even if you're happy with the existing colour, repainting it can work wonders.
Discoloured, peeling and patchy paint isn't pretty or practical, and can lead to damage that's expensive to repair.
2. Try different colours
While you can rarely be as adventurous with the colours you use on the outside of your home as the inside, you don't necessarily have to stick to white, cream or magnolia.
However, you do need to consider what will go with your neighbours' houses, if there any restrictions (such as planning ones) on the colours you can use, and what suits the style and period of the building.
[Read more: Planning permission: 5 tips to make sure you stay on the right side of the rules]
3. Rendering
Having the exterior of your home rendered can really smarten it up, even if it's just the front.
Coloured renders are available, so if you find a colour you like, you won't need to paint the render, saving time, effort and money.
With modern-looking properties, wooden cladding (or faux wooden cladding) can work well, especially on the front.
4. Add a porch
Another good way to improve the front of your home, especially if it's plain and lacking character, is to add a porch.
The porch should, of course, be in keeping with the style of the building and needn't be elaborate - a small roof and something to hold up the roof may suffice.
Changing the windows and front door, or replacing an unsightly porch, can also make a big difference to the look of your home.
If it's a period property with ugly modern windows, for example, fitting period-style windows will transform the exterior, and interior, and probably make it warmer and quieter too.
5. Find out about restrictions
Before you start changing the exterior, find out if there are any restrictions on what you can and can't do.
Listed buildings usually can't be altered without obtaining listed building consent from the local council, for example.
If you live on 'designated land', which includes conservation areas, you may not be able to do what you want with your home's exterior, or you may need planning permission, especially if your home's permitted development rights have been removed.
